dodge truck chop
this one came back in to have the frame shortened. i am personally not a huge fan of the super stretched out chassis look, and the owner wanted it to steer and drive better. so i am taking out 15 inches of the chassis. which makes is 134 inches long, still a little long to me, but much better. and not as much work as making it shorter.
front of the old chassis cut off
had to cut the floor our to slide the engine and trans back 5.5 inches
tapering the front rails
internal gussets, will leave a 1/16 inch gap to burn in deep, plus be plug welded
new rails tacked in place
motor mounts tacked in
I had to restrain myself about mentioning that It looked too long. I try not to be negative. I really like it now! Great workmanship!
some more progress from today
worked on getting the grill shell fit up
got the steering mocked back up, at a much better angle, the old set up ran the drag link at a 45* angle
vega box
the steering off the pitman arm hangs low, heated and bent the pitman arm to get it level, just forgot to snap a pic of it afterward
started getting the headlights back on as well. used an early ford head light bar, cut it down to used the forged ends. heated and bent them into shape
got everything all mocked up, ready to blow it back apart to weld everyhting solid
and here is a pic of the pitman arm after i heated and bent it to get the steering lined up
the steering looks low to the ground in the pic, but it is an optical illusion
You have done an amazing job to make that truck look way better than the original build!
Is it lower than the bottom of the axle?
Was just curious, as maybe a straighter steering arm would let you move up the box, and not be below axle level?
no the steering does not hang below the axle, it is just a super weird angle. if you look at the front shot you can see that it does not hang very low. the problem is this not an ideal set up with parts that are on this truck ( owner wanted to re uses all the hard parts ) i cant raise the box because it will hit the bottom of the radiator or the fan.
got the truck all finished up on friday morning and put about 60 test miles on it. everything is great. here are some pics of the finished product
here is the tunnel in progress, welded and seam seam sealed and some in between
