I went to lower the lights and discovered the front sheet metal needed some more braces. Spent a while pondering and working on that and decided to just wire the tach up and start the ole 429. And of course, I'm going to have to remove the tach and take it apart to check that the little switch is on 8-cylinder. I guess that's the trouble. It's reading about 1900 at idle. It should read about 1000-1100. Green wire is to "Tach" on distributor cap, RED wire to "HOT" when running, WHITE wire to "LIGHTS", and BLACK to "GROUND". I got that correct don't I ?? It's been a while and the remember isn't kicking in today. Later.
