C0dy
Whose running duals on a mild sbc 305? What's your setup
Tunnel rams are for high rpm, max horse power. Any motor will need good heads and a big cam.
Undersized carbs are a bandaid to try to make it work at lower rpms. A single 4 on a dual plane intake will run A WHOLE LOT BETTER!!!!
Haha I like the idea of a dummy carb but with this manifold it seems like if I did that only the back (or front) cylinders would get fuel.
I'll let you know, i'm putting the same manifold on a 350, the top section is an open plenum so i'm thinking it might work[S
