Exhausat Ideas
Charley Davidson
Caps for gas bottles might work well or small gas bottles cut in half
Great idea CD!!
I do have to consider weight as the rockets, pipes and collector will all be cantilevered off the heads.
I'm on my way to the 18 degree garage to look at a cap now....
Colton, I suspect that by dispersing the exhaust from that little old tired 6 banger into 6 pipes that it will have a hard enough time lifting six 2" flappers :eek:
Now the next question is material, if I go with the Gatling gun look I think regular steel exhaust painted black will look the best.
If I go with the pipe organ look I'm not sure. I could get some thin wall 2" stainless @ the scrap yard pretty cheap, or find some old drag pipes, or regular exhaust pipe?
galvanized fence posts?
watch the fumes.... lol
The idea with the roadster pickup is...be different!!!...instead of running the pipes between the deck or up the cab or???...why not send them out the side of the front fender pointing back at about a 45 degree angle or greater...nothin says evil like two gatling guns blasting out of your fenders....dare to be different?
With time & money restraints plus the need to get my stinky, smokey exhaust fumes away from the drive through windows I made this temp exhaust out of stuff I had on hand, mostly stainless motorcycle exhaust & part of a 4 cylinder stainless header from a sports car, need to weld 1 more bracket and a leak at the header/muffler joint
I'll say one thing...YOUR TRUCK HAS BALLS!!!!!...how many you have back there?...you should put a 13 of spades plate on them pipes to connect them together
