cornfield customs
are you pushing or pulling the weld puddle? when pulling it will have more build up and less of a consistent look. pushing also helps with penetration as you are pushing forward into the joint
Cut into the weld and check your penetration. Might as well.
Why hasn't anyone even mentioned his Argon/CO2 mix setting? I know that most machines want 18cfm max. But then again, I don't know Millers.
Hey B3b23, you asked how we can tell that you're moving too fast. The answer to that is really easy. Your welds lack consistency. You start out pretty good, the bead looks tight but then it's like all hell breaks loose and either you get antsy to have it done, like your hand is on fire or somethin. You can always stop to let the weld cool down and when you start back up, start ahead of the original bead, work your way back into the original bead and then move forward. One thing I have found that works wonders, is hold the stinger in a fashion that feels natural. Ie, if you are looking at the plates you are welding from in front of it, hold the stinger sideways and move left to right or right to left. Also, depending on your light source( mine sucks in my shop) turn your welding hood down a bit so you can actually see the bead. When I get a chance, I'll try to snap a picture of one of my better beads.
The biggest thing is patience. You have to have a lot of it, especially if you're doing really thin sheet metal. If you're having trouble seeing the arc, try to turn the stinger sideways a little like a 45 degree angle. That may help. It's so much easier to just show someone what you're trying to explain but I think you're starting to get the hang of it. Keep practicing on scrap metal until you feel comfortable enough to actually weld on something that matters.
Does the smaller cup help with the shielding gas? More concentrated, maybe? [S
Actually it does help especially on a windy day.No, the gas is the same, but you can see around it better, and get into tighter places.
I do a lot of repair work on semi car haulers and I do it all outside.
I used to use the factory cup. I experienced trouble with the wind blowing the shielding gas away from my welds without running the flow almost wide open
I found these at Scott Gross Co. I bought one just so I could get into tight places and found an add benefit, the cup does concentrate the gas in a tighter area and I only have to run the flow between 20 to 30 on a windy day now.
The cup paid for itself within the first hour of use
