lvin4jc
I'm working with a '62 F100 here. It had 6 leafs up front (I-beam axle) stock, I took out the bottom three and dropped the front end a few inches, but of course I want more. I have fully researched flipping the axle, MII setups, dropped axles and drop leafs, however I have other things that i'd rather spend what little money I have on.
I ran across an idea that sounds reasonable enough, basically a poor mans way of accomplishing a reverse eyed main leaf. The idea is to take out the 2nd leaf, flip it upside down and bolt it down on top of the main leaf. That way you still have the strength/support of the same number of leaves (3 in my case) but it flattens out or lowers the leaf pack and therefore the location of the spring eyes.
Maybe this is an old trick and some of you more, um... "seasoned" rodders will know any pro's or con's with this setup. I'd love to hear your thoughts.
- Joe -
- Joe -
