Old Iron
At the front, the center of the crank is 15" off the ground and centered between the frame rails.
The output of the tranny is also centered between the frame rails.
The engine and tranny are tilted down from front to back 3 degrees.
The 2 1/2 " offset of the 8.8 rear will most likely not matter.
The floorboard tranny hump is 5" high and tapers from front to back.
Not sure if this is the info you're lookin for so, if it isn't just ask and I'll try to get what you want.
