35DODGE
Active member
I had these shock mounts brackets cut out at work. I would like to know if anyone sees an issue with this set up. I have a guy that lives near by and says that I do not have enough travel with the shocks. According to the manufacturer the shocks should be mounted 12" center to center. The only issue I can see is between the spring shackle and lower portion of the bracket . There is about an 1.25 clearane.
