neverwintercycles
- Joined
- Sep 13, 2008
- Messages
- 12
pics are here
http://www.kodakgallery.com/ShareLanding.action?c=cp1wtlp.8x1qw221&x=0&y=-4t4k44&localeid=en_US
original leaf setup had 7 leaves, i removed 2 and used 1/4 thick steel for the lower shock mount. upper shock mount will be fully welded and bolted in place once the position is set. the shock is mounted directly above the axle on both sides. and the axle sits on top of the leafs springs instead of below like it did originally as i wanted to drop the front end a bit. i can always go back to stock if it will work better.
can anyone tell me if this setup seems like it will/won't work? i have no idea about stress loads, shock angles, etc. def interested in thoughts/criticisms/suggestions. i want to be safe in this thing!
thank you
- jason
thank you
- jason
