izzy
running around 1980 ford 302 with external voltage regulator cant seem to get the alt to charge to battery. any help would be great.
here are a diagram :
An easy way to check if your alternator is bad..start the engine...disconnect the battery while the engine is running. If the engine dies then chances are you alt is bad. if it stays running then you have a wiring issue or a regulator problem.
When I first got my 27 running years ago it wouldn't charge either, and I was also running a 302 with the standard Ford regulator. Took it to an alternator shop and the guy found I had forgotten that little ground wire. Hooked it up and it charged fine. Just a thought.
common problem......
i have an 80 ford and the battery wasnt charging -- decided id nail the problem and replace the battery, the alternator, the battery terminals, and the wires....
well - still didnt charge -- it was the regulator itself-- 16 dollar part lol -- just saying.
Gets really expensive throwing parts at it..... that's why I always recommend checking the basics... power, ground, connections when it come to electrical issues..... we've all been there, done that!!!
