Thanks for appreciating how much work the roof was Perley! Unfortunately, I don't have any better pictures of the roof ribs. I made them out of 1/2" X 1" tube. I ran a couple along the length of the car first - I shaped them to the curve of the car, then welded them in along the top of the sheet metal. To make the ribs, I bent the ends around a propane bottle, and cut them off to the height and length that I needed - mimicing the curve in what there was of the original sheet metal roof. I made them progressively shorter and flatter as I worked toward the front of the car. For the roof metal, I bent a 4" pipe to the same curve as the shape of the car, and tried to wrap the sheet metal over that. As you can see, I ended up with a couple of really bad "pleats". I stretched the pleats using a dead blow hammer and a bag of sawdust, until I had something close. Once it was on the car, I did have to make about 4 relief cuts in either side, and it turned out ok. It's a little flatter than I would have liked, but I think it will look ok. I put some really dense 3/8" foam on the ribs before I installed the sheet metal, in order to prevent any welding, or squeaks. I hope this all makes sense to you. If not, PM me and I'll try to explain it better....
