HandOverFist
Lol! Whatever happens up front it will be bolt-on, so easily replaced if necessary.
Could you downsize the barrel and follow the shape of the top portion of the grill. Barrel piece goes under grill with lines being horizontal. Mustache goes away [S
Cut 6" off the teeth, cap and add a piece of the barrel...
why don't you just take all those snow plow bars off, extend the upper grille down, then use the lower ones to make the lower part look like the top. something like a '32 ford grille shell. it couldn't look any worse. this front looks fine on the original truck because there are other parts that take up space, i.e. fenders and such. i think your idea of using full length leaf springs is a good idea too. less clutter. besides they have been used for who knows how long and are very reliable.
I like that look
What about another grille center section turned upside down and connected to the upper with something on each side too?
It would look similar to the 40 Chevy pickup grille.
Maybe Doc can PS that.
I was skeptical about the half barrel tank but is looks good.
Yup, it does look pretty cool after all. Good luck with the door windows...they can sure suck up a lot of time!
