Heated a piece of steel to bend....will it bend back?
Couper
RRR Supportor
Aug 26, 2020
1,464
Northern NJ
Hey guys, I never really understood the procedure for this.... I heated to red a piece of 1/2 x 3/4 steel to make a thru the floor riser pedal holder for my brake lever. Very slight football arc if you will over 8".
Can I just leave it to cool slowly or do I have to quench it in oil so it won't bend back? When done I will need to weld this to my lever. Thanks!
I do what you did, quite frequently. Just let it cool normally. It might straighten out very slightly, but then you can just whack it with a big hammer to get that one degree of bend back. The metal strap that you are using is heavy enough that you don't have to temper it by quenching it. Carry on.
A piece of mild steel that is 1/2" x 3/4" that was heated to bend, and allowed to cool normally should hold up OK under normal circumstances.
If its under a lot of high stress, over time (a few years) in may straighten, or bend more (depending on the direction of the high stress). If the bend did change over time, applying heat to correct the bend, and letting it cool normally, will probably last as long as it did the first time.
After a little imagineering, I decided to do something a little different . Instead of welding just the pedal extension to the lever I decided to make a longer piece, bend it and will weld it lengthwise, or bolt it to my lever. If I weld it, I'll have to remove the cab to get it off, so I'm thinking 4 or so hardened button heads
    104.3 KB
    139.4 KB
you will be fine with grade 5 unless you just want grade 8. most people lift a engine either with 2-3/8" bolts or 4-5/16" bolts on the carb mount, most of the time grade 5.
So I bent up a new piece today. The stock I was using was 1/2 x 3/4 and standing on edge. I'd have to drill for 1/4" tappings in 1/2" material not leaving much strength....the lever is the same material but laying flat. I picked up a new piece of material 3/4 x 5/8 and bent it so the 2 - 3/4" surfaces will be flat against each other so drilling the 1/4" tappings in 3/4 will be better than going into 1/2. Moving along, one thing at a time.......
could you not make the whole lever arm? not sure it your doing brakes and or clutch, the t bucket guys do it all the time.
If I make it 1 piece I'd have to unbolt and lift my cab the amount the arm comes thru my floor board to get that assy off....that would be a real pain. I may never have to do it but just thinking ahead should I have to.
ok i understand. if you weld it it would be better. the chances of removing the arm should be small, as long as you can get to the rest. i wouldn't weld it 100% either.
Just guessing here, but even if its bolted into place, once the motor and trans are in, could you still unbolt it if you needed to?
There are going to be things on your build where you just have to be thankful you probably won't have to deal with again.
Yes....very easy to get to. See above pic. I'll attach one when finished.
if your going to stack them like in the pic, make some plates. 4 or 6 bolts plate on each side bolt holes through each piece and sandwich them together. say two pieces of plate say 10" long 1 1/2" tall drill 4 holes on each side of the plates sandwich the bars between and drill holes to match and bolt it all together maybe add a couple weld tacks to boot
