Heated a piece of steel to bend....will it bend back?
Couper
RRR Supportor
Aug 26, 2020
1,442
Northern NJ
Hey guys, I never really understood the procedure for this.... I heated to red a piece of 1/2 x 3/4 steel to make a thru the floor riser pedal holder for my brake lever. Very slight football arc if you will over 8".
Can I just leave it to cool slowly or do I have to quench it in oil so it won't bend back? When done I will need to weld this to my lever. Thanks!
I do what you did, quite frequently. Just let it cool normally. It might straighten out very slightly, but then you can just whack it with a big hammer to get that one degree of bend back. The metal strap that you are using is heavy enough that you don't have to temper it by quenching it. Carry on.
A piece of mild steel that is 1/2" x 3/4" that was heated to bend, and allowed to cool normally should hold up OK under normal circumstances.
If its under a lot of high stress, over time (a few years) in may straighten, or bend more (depending on the direction of the high stress). If the bend did change over time, applying heat to correct the bend, and letting it cool normally, will probably last as long as it did the first time.
After a little imagineering, I decided to do something a little different . Instead of welding just the pedal extension to the lever I decided to make a longer piece, bend it and will weld it lengthwise, or bolt it to my lever. If I weld it, I'll have to remove the cab to get it off, so I'm thinking 4 or so hardened button heads
    104.3 KB
    139.4 KB
you will be fine with grade 5 unless you just want grade 8. most people lift a engine either with 2-3/8" bolts or 4-5/16" bolts on the carb mount, most of the time grade 5.
