pistolpete
Wondering what issues I may run into here, or am I over thinking. What I want to do is use a '40 Ford axle and wishbone, hack off the spring mounts on the wishbones, and run a spring over the axle. I can not locate a spring perch that says specifically that it will work with the '40 axle and wishbone, but I assume that it would be similar to using a '32 style perch on '40 split bones as has been suggested to me before.
I want to try to build the car without splitting the wishbones at all. Just trying to figure out if it is possible, and then round up the last couple peices I need for my front suspension.
Specifics, '30 Tudor, looking for a flathead & tranny (thats a thread for itself), '40 front axle dropped 3-4", '40 rear axle with a 2-3" drop on the rear crossmember. Thanks,
