smallfoot
You're gonna like those gears. I have 3.08 in my 31 and thought they would be too mild until some people here corrected me. Plenty of umph in a light truck...2.75 should be great cruisers...!
Yes, very happy with the change....You're gonna like those gears. I have 3.08 in my 31 and thought they would be too mild until some people here corrected me. Plenty of umph in a light truck...2.75 should be great cruisers...!
Hate to hear that.
The last SBC I built done that, when I re-done the build I put a roller cam and a set of roller lifters in it, problem solved. I'd have been money and labor ahead to of went that route to start with.
Roller cam and lifters for an FE Ford is like $2000.00 Canadian, hard to justify it for this engine....Modern cam and lifters suck compared to the old stuff.
Sorry for what you have to go through now.
My experience with losing a lobe on the cam has been because of faulty lifters. Back just after Covid, I bought a new cam and lifters for a 455 Buick I was building and lost a lobe after doing everything I knew correctly. Then, I ordered another cam and another set of lifters and had a buddy come over to listen at start up. In just a couple minutes, he gave me the cut it off signal. I removed the intake and found I had 2 dead lifters but it looked like there was no damage to the cam. I disassembled both lifters (Eaton) and neither had springs in them! So, I then disassembled the lifter with the first failed cam (Johnson) and found that the ball check seat was pressed in crooked and there was no way the lifter could pump up. Fortunately, replacing the 2 lifters in cam 2 solved my problems and 6000 miles later, the engine is still quiet. So, I would take a look at that lifter, Charlie. You may be surprised at what you find......or don't find.Yes, very happy with the change....
On another note, today was an epic fail, wiped out a lobe and lifter on the new Comp Cams Thumper cam
Did all the usual lubing of the lobes and bearings, lifters, pushrods, rockers, etc., - even purged the lifters before putting them in and used hi zinc oil, to no avail...
Ten minutes in on the 2000 rpm break in one rocker started clacking for a minute then stopped - figured maybe some dirt plugged the lifter ?? Then at about 15 minutes it started hammering again. Finished the break in time and it's still doing it. Being a moron, I took it around the block, hoping it would magically go away. Nope. Drained the oil and found the telltale silver pearly color...
Guess what - it's out of stock from Comp and others like Summit. I'm actually considering putting the old cam and lifters in from the 360...
Or looking for an alternative - more $$$$
Sorry Bob, I don't know where to find one here.No comments on the use of reground cams? Works for me. Also, I check new flat tappet lifters for slight crown on the bottom. Lifter gotta rotate.
Oh yeah, used to do that all the time, used cam, mix up the lifters, so on, no break in run - no problems...That does suck!! I have had a few go bad on break in on Me also. The last comp I did I let it idle for a few min then went and drove it. No 2000 RPM break in sitting in the shop. That's where all mine have failed. It survived, not sure if it was the better thing to do or I just got lucky hahah
That makes sense, also watched a couple other vids.Here's the video that I thought was reliable......at least as reliable as anything WWW these days!
https://www.youtube.com/watch?v=ohR5rcuYPr0
Wouldn't you know it, they don't make the DLC coated ones for the Ford FE engines...The one thing some guys miss on the break-in is spring pressure. If you have dual springs I think most manufacturers say that you have to remove the inner spring for cam break-in.
Same as LB, the comp in my 455 Buick never had a proper break-in. 36,000+ km's later, it still looks perfect. But I bought that cam in 2011 or 2012, things have changed.
Comp has lifters with a new DLC (diamond-like carbon) coating on them. I've done a lot of testing on DLC coatings in a previous work life and the reduction in friction makes it a good option for this particular application, as long as they have the adhesion of the coating figured out in this application.
Of course not. Darn it.Wouldn't you know it, they don't make the DLC coated ones for the Ford FE engines...
No, they are the Comp springs that came with the cam, I'll remove the inner dampers for the next attempt - a real PITA but if it works out, it'll be worth it.Of course not. Darn it.
Are you running stock valve springs?
