Oldphart
I'm in the process of installing my first ever triangulated four link suspension in my 27 Tudor using a Ford 8" and coil over shocks and I have a few questions. I've read lots of posts on the subject...to the point where I'm a little confused...maybe more than a little but I have a plan.
1. I can fab brackets to get the lower control arms parallel to both the frame and the ground, keep the driveline relatively flat and still stay well above the scrub line so I think I'm OK there. My frame is 27" wide and the axle 54" at the flange. It would be easier and probably a bit stronger to mount the bars directly to the outside of the frame but I could fab brackets to move them out further. Is there an advantage to spacing them further out toward the ends of the axle?
2. The longest lower arm I can get to work without major mods to the body and frame is 19" the upper would be 14". I believe the proportions are correct but are they long enough assuming 3" of upward suspension travel? That may be a silly question because there's just no good way to go longer.
3. By welding the brackets for the upper arms to the center of the axle housing I can get about 90 degrees (45 per side) with a slight upward slope to the attachment point on the frame. I've read conflicting info on the best angle some say 90 is best some said more like 70 degrees. Anyone have experience here?
4. As I mentioned I'm planning for 3" of upward suspension travel. When I buy the shocks should they then have 6" of travel with the suspension sitting at halfway with the weight of the car on it?
Thanks in advance for any input.
