AZRodDave
Yeah, you are right. Sure do like the lines on it, but getting the curved hood line at the back to match up with the straighter line on the cab would be quite a challenge.
I think the cab needs to move back just a little, or maybe it will look ok when you get it leveled up. I think the Frieghtliner grill is gonna look too big, just my 2 cents.
If you are using front fenders, etc., you will need to center the wheel openings over the wheels, then work backwards. That gives you your cab location. Once you know that, you can do a bit of surgery to the floorboards to fit around the trans. I spent a long time fitting my 38 to the S10 frame and making everything line up. Kind of like a puzzle where some of the parts don't quite match. Slow is good when you don't have a set of directions. Any 55 to 59 fenders will work for positioning the cab. All that said, It looks to me like the cab is way too far back for the front fenders to land over the tires. So, once that is sorted out, the tank might be ok. Maybe even the bed mounts that you cut off.
If you don't have fenders to fit on it right now, measure the distance from the front of the door opening to the center-line of the front wheels on the other tri-5 truck. It will have to be the same. You do have instructions. Cool!
... removed most of the screws from the trans cover plate and it WAS up a couple inches in the front ...
I love those little victories!Maybe not too thrilling for you more experienced folks, but my first time trying to build something out of mis-matched pieces, so every little victory is HUGE!
When you get that cab situated where it will live, you may have to shorten the steering intermediate shaft. I spent a lot of time sorting that one out, but it was way cool once I got it.
Keep playing.
I just remembered, there used to be a 57 truck like that running around this area that had a 57 Chevy car front clip on it. It looked good and strange at the same time............
