This is what makes it GOOOOOOOOOOOO
A Windsor 351 stroked to a 396 cu in, 915 Canfield heads,
custom cam by Jay Allan "camovations"
Engine dyno'd at rebuild 455 HP 477TQ
I have never found the Fox Mustang appealing, but I changed a few things on my 88 GT to help
Hand built a NASCAR style rear spoiler
Moved antenna from front fender to rear trunk
Took a scoop off a 03 04 Mustang and made a function ram air
Changed the appliance white paint to a softer white
and put some 17" torq thrust wheels instead of modern wheels
The air cleaner sit up through the hood, so element is in the scoop.
I used velcro on the scoop grille so I can put it in for rainey weather, then take it out for sunny days
I ripped out all the Ford gauges radio etc. and installed all autometer stuff
I know it is hard to see but if you look closley you can see where a placed the side impact roll bar forward right under the doors arm rest as it makes it way to front of car frame, Makes it very easy to enter and exit car plus it protects cups your hip & leg
