The Rattler Well-known member Joined Jun 23, 2007 Messages 292 Jan 17, 2015 #1 Setting up my radiator and wondered how far it should be from the fan, I am using a shroud. Thanks in advance, Rattler
Old Iron Well-known member Joined May 19, 2011 Messages 15,290 Location Willard Mo. Jan 17, 2015 #2 With a shroud you can be a long ways. Rule of thumb on a shroud is about half the tip of the fan blade should be inside the shroud. So half in half out
studebaker59 Well-known member Joined Jan 12, 2014 Messages 66 Location Cusick, Wa Jan 17, 2015 #3 The fan blades should be half way in to the shroud. So I guess it depends on the thickness of your shroud.
