I.F.S.
S10, but you will need wide wheels for fill the wells. Not necessarily a bad thing. My 39 (see avatar) has an S10 under it, and I had to use 8.5 wide wheels to get it looking right. It is much lower now, BTW.
It's a good front end. Easy to work on. You need to match the wheel/tire width of the vehicle you are building to the donor vehicle. Or find a wat to adjust with wheel of set.
I see a lot of guys using them on FTE. Personally I don't like the looks of them on a vehicle that originally had a narrower track width and am not a fan of the offset (look) of the modern wheels they are designed for. I do have one under my 2003 Gran Marquis and find the steering too quick off center and twitchy to get used to.
Write your reply...
