donsrods
Hey, Ron, I have three questions:
1) Dan wants to know the thickness of the front axle so he can weld those spring perches on correctly.
2) Do you carry just one 4 bar front mount or more than one ? I need to get two sides from you so I can make my kickup the right height. I am basically putting a straight 90 degree kickup on the frame because you mentioned it is best to have the 4 bar mount welded directly in line with the frame. So I need to know if you have different lengths or just one standard one.
3) It looks like my 4 bars can not be any longer than 10 inches. Can you make them that short (rod end hole to rod end hole overall length) ?
Today I cut the frame rails to 90 degrees (45 degrees on both parts) so that the kickup will be a straight wall. The first thing I did was put both frame rails on the the bandsaw and clamped them together. I ran the front round crossmember down through the holes on both so that when I cut it both pieces would be exactly the same length.
Then I put the rails under the body to see how it would look, and propped up the front and rear tires to get the overall picture.
Since I am now putting the coil overs directly under the frame rails (instead of my original plan to put the outboard of the frame) I can now move my slicks way inside. It should handle better and I like the look even more.
