Flatbedcowboy
- Joined
- Feb 4, 2019
- Messages
- 5
Hello,
I have a 1948 International KB11 with factory air brakes (kinda rare), and all the original equipment has not been changed.
So I need help identifying what the heck all these sticks are for! There are three , plus a lever on the column.
The one on the column Ive been told is for turning off the trailer air brakes for sharp turns. Make sense since it goes into the air valve by the brake pedal.
The next stick on the floor (headed to the right), only goes forward, center, and back. The knob says "Do Not Leave in Neutral".
The middle stick, is for the 5 speed transmission and has a reverse lockout.
The far right stick has a hand lever and goes forward, center, and back only with the lever pulled in.
As far as I know the far left stick and the far right stick both run back to a "second transmission" that is bolted behind the 5speed.
This truck doesnt have a 2speed rear.
[/url]IMG_0330
