jmlcolorado
Wheels are turning, and tires are skidding sideways. My work here is done. [ddd![]()
Yeah. Thanks for that. I guess
If you lengthen the bed and not the wheel base it will not only look funny but will take too much weight off the front axle. leaving the hoist too far forward will keep it from dumping at enough angle to empty out . I built a truck with a lot of over hang in the rear and it was interesting at times to say the least.
Jml, I've always used the formula for box placement at 60% ahead of the axle and 40% behind. This looks nice, proportionally.
I have only installed dump boxes, but I need to be careful to get my load right on each axle. If I was mounting a dump box I had to keep the hinge fairly close to the back so there was not too much over hang. If it was a grain truck I needed a foot and a half of clearance at the back of the box to the ground when the box was raised so I didn't crush the auger hopper, that I was dumping into. If it was a truck gravel box I needed two and a half feet of clearance to the ground at the back so I could miss the pup trailer hitch every time.
For its intended purpose, I think you are 100% headed in the right direction. If it was just for going to shows and letting people stare at it, maybe not so much. There are Y-block fans out there. You should be able to get some of your investment back. [clOkay welp, no turning back now.
https://youtu.be/S7YyZ75ixyQ
I’m still seeing this as one of the quickest (as far as labor intensive) builds to date.
No trying to convert brakes over to something else.
No new wiring everything (except lighting)
No cobbling together drivetrain pieces that work together.
Body on a driving chassis.
How hard could it be!?
Famous last words.......
I don't like having to scrap something someone else can possibly use either.
[P[P[P
