jmlcolorado
Crap takes too dang long when all you have to cut with is a 4" grinder
I need to get a plasma!
How about putting the strut at the bottom. Go from the point back to the cross member. It worked like a charm on my 51 that had the tractor grill.
And who can resist the initial headlight placement photo [cl
Initial? I think you just might have hit a 'hole in one' man
[P[P[P
Would go just a little wider myself!!
Killer look!![P
Look up why they dont use iron nails on a copper roof =)
Lookin good!
Ever thought of going to a rack up front? kinda like this mustang unit I did on a 70 GMC chassis? Just a thought. It would put your steering shaft inside your frame and clean up the front horn where the box is now.
I got to say that I was a little sceptic of the IFS look at first, but will the grill and the way the front end turned out I applaud you, sir! [cl[cl[cl
Keep up the good work!
-Troy
I'm not sure why everyone doesn't move things around to make them look half good. Really isn't that hard. No harder then making the rest of the truck look right.
