endicott_jb
I don't exactly know. I was just taking a shot in the dark. I think I have a gm power steering box out back so I'll check and get back to you in a midget.
Okay, I think I fingered it out for ya. The box you're using uses a 11/16x18 inverted flare(not AN) for the supply and 5/8x18 inverted flare for the return ports. Now, looking through my speedway(which doesn't have every adapter available) they offer plenty of pipe to AN adapters but no inverted flare to AN adapters. I'm guessing what you have right now is a standard pipe to AN on your supply side which will go together but will spray like a SOB under pressure from the pipe threads and on your return side you've got a pipe to compression adapter. But please don't quote me on that cause I've been wrong a few times.
From my experience power steering fittings are always a pain. Gotta Show http://gottashow.com/ will know the answer and have a solution if you can't find it anywhere else.
