earthman
I have to commend you for your perseverance in building out in the open like this. Good job.
It's alive...
I had to make a longer push rod for the clutch fork as it wasn't going into gear, but with that sorted I took it for a drive down the street
http://www.youtube.com/watch?v=KbMQK_P-J4A&feature=youtu.be
It's alive...
Those latches might be interesting. You need to meet this - http://www.infrastructure.gov.au/roads/motor/design/pdf/02.pdf
They no doubt do, but proving it is the hard part.
Easiest way is to use some kind of OEM latch, that way someone else has already payed for all the testing and certification...
It's hard to know what they are going to get picky on. I spent probably 20 hours building my windscreen wipers getting them to comply perfectly with the ADR and they didn't even check that they worked.
And then they picked up on other little things that I really wouldn't have thought important. I had a couple of 10mm holes on the inside of my door where someone had poked a drift through to knock out a dent. I had to put grommets in the holes to pass
Depends who you get on the day as to how hard they make it, but meet all this (plus basic roadworthy and decent/correct engineers report) and they actually can't deny you registration:
http://www.infrastructure.gov.au/roads/motor/design/second_edition_adrs.aspx
Sounds like over the ditch is nearly as strict as here....nearly
