Mr.Crown
I just am unsure how I would adapt ones from the "bung king" or which ones I can use lol
http://www.bungking.com/bungs-5/petcock-npt-bungs/aluminum-npt-bungs.html
No kidding! I had to do a double-take on wether or not I was on a dirty website.
Agreed on the airline fitting comment. Maybe you might want to consider fuel valves from a motorcycle that thread into your keg. They make various sizes to fit different diameter hose. Aftermarket stuff for fuel valves is pretty massive...
Dumb question...
why not just put a fuel sending unit in with a gauge from a car/truck?
Fuel sending unit? I'm going to on the assumption you mean fuel pump, if that's the case the pump is on the motor.
No, I'm an idiot. I just finished working on some new songs with the band, and the loud noise hurt my brain...
I meant a fuel gauge sending unit...you know, electronic. Goes from tank, to gauge on your dash.
Maybe this thing?
http://www.summitracing.com/parts/CLP-AGT-BFIK90/
Or maybe I should just shut up and go lay down now...
Gotcha! You're right, I'm wrong
I think that my sending unit is bad, plus I'm okay with the idea of running a odd ball style fuel gauge lol kinda like the idea
"Sight glass" gauges have been around a LOT longer than electrical ones.Gotcha! , plus I'm okay with the idea of running a odd ball style fuel gauge lol kinda like the idea
I was assuming it was stainless. Which is it?Ok, so under the assumption that the keg is aluminum?
I buy old kegs (the barrel looking type) antyime I come accross them. I have about 30 (and I dont even drink ). Only 2 of them are aluminum, the rest are stainless.
Unless they do it different in Canada, no, they are all stainless. I used to think they were aluminum too, untill I started tigging one on the wrong settings,lol.well that would explain it...I think all the new kegs are aluminum...?
Almost every one I buy a keg from says "its worth more than that in aluminum scrap". And I get to argue "yea, IF it was aluminum, shame its stainless".Pretty easy to tell the difference, especially when you pick it up.
Be sure and install an in-line fuel filter too
