LA 318 & 904 trans
23crate
Moderator
Staff member
Moderator
Sep 26, 2014
1,387
new zealand
HI ...
any thoughts on a more economic option ?
was chatting to a buddy of mine last nite was claiming around $37.75 of gas to do 344 miles ~ ive worked this out to US dollars ~
hes running a 327 / 700r4 in a twin spinner so theres a little weight
we pay $8.01 for a gallon ( yes I know raped then robbed for gas !!)
SO then after all that .. what if any is a good gas mileage trans for a LA series 318 ?
thanks
Crate
A A518 overdrive from an 89-92 Dodge 2wd dakota, durango or full size van, the later ones are electronic and need a computer to run them.
Every engine has its "sweet spot", where a few hundred RPM can be the difference between poor mileage and good.
At cruising speed, you want your motor to be its powerband, unless it's a very light car. For example: If the 318 doesn't make torque until 2200 RPM, don't ask it to spin 1800 and deliver mileage.
Obviously, an automatic OD has its advantages. Most have a lower 1st gear and naturally, an overdriven 4th. You need a properly matched diff ratio and tire size to benefit from any transmission's ratios.
I would find the 318's specs and the ratios for your transmission candidates... plug all your numbers into a calculator.
https://www.ringpinion.com/calculators/Calc_RPM.aspx
Thanks Dr C theres abit to think about there.. I guess there any cam work, head flow work , can alter torque to factored into that
for some reason I was working on some generic application, but is not quite as easy ..
dam good start that link !!
Bama had a look at the Gear vendors site .. poss a bit pricey at this stage ~ but its early days in my build. so come to that ..
or even look at the A518 ..
before all that I get my sh#t sorted..
Thanks All
