Ladder bar and spring mount points...
DOUGIEB59
Aug 12, 2010
133
MID TN, NOW
HEY FELLERS... AM BUILDING MY FIRST RAT, HAVE NAKED FRAME RAILS, NEED INFO ON "ENGINEERING" SPRING MOUNTS, LADDER BAR MOUNTS,CROSSMEMBER SETUP, AND FINALLY DRIVE SHAFT/U-JOINT ANGLE...
MY BRAIN HURTS... D/B:confused:
Hey Dougie, Pretty soon it will be either ice fishing time or hot rod building time in MInnesota. Glad to see you chose building. Before members try to answer your questions it would be valuable for you to go through the many fine bulds on this site. If you put in a couple long nghts doing that the answers to most of your questions will be evident.
Good luck on your build and don't forget...,post pics.
