For the most part, 4 layers of 1 1/2 oz. mat. Just under 1/4"
Later on as it goes on I'll build up here and there, add some core mat and unidirectional cloth where needed.
The windshield frame had to be molded in two "C" shapes, front and back. The layup was heavy to give a 3/8" edge after grinding. There's a spiral wrapped length of 3/8" all-thread with e-glass running through the frame. Then the two halves were epoxied together. The pillars were packed with shredded glass, capped off, and vacuum infused with epoxy resin.
The windshield frame is stronger than the original.
As I said earlier. Extremely well done!
I have plans in the works to do a "Roth" type build using the same methods that he did so it will be a one off build.
Still working on wether it will be a bubble top or not.
Keep the posts coming.
Torchie.
