Just joined yesterday and already impressed with all the great help and info here. Thanks! I'm building a 27 Model T 2 dr and using a Model A frame. I have a 46 Ford front axle and a Ford 9" for the rear. I want to keep the model a frame horns, but am struggling on how to mount the spring to the axle. The picture shows it mocked up when I moved the car, but is there spring perch mounts I can buy that bolt/weld to the axle so I can use the model a spring, or is there another spring set up to use? Thanks for any help you can provide!!!
