King Herald
I have a lightly tuned 350, mild cam, 11:1 CR, HEI dizzy. Intake is some sort of early Chevy alloy stocker, with Speedway T bucket headers. It used to run smooth, but had a lifter clicking loudly occasionally, #5 intake valve. Couple of weeks ago I pulled the intake and stripped and cleaned the lifter, seemed to work okay, until the engine got to full temp and it started clicking again erratically. Cam lobe was good.
Also had a little game modifying the HEI to get a little more mechanical advance, as it only gave 12 degrees mechanical as supplied. Now it gives about 20. I'm running the vacuum pipe to manifold vacuum, not ported, though I've swapped it back and forth and it makes no difference except the idle needs adjusting. I run it at 12 static (so about 30 full mechanical) and an extra 15 so from vacuum at idle.
However, at some stage of all this I noticed the idle was rough and traced it to #8 cylinder. This cylinder gives about 130 psi on compression test, others are all 140-150. Header temp on #8 is about 300f and the others are 500f at idle.
I did a home made leak down test, ran 120psi into the cylinder but could hear no hissing from exhaust pipe or carb, so it seems to seal quite well.
I swapped the plug for another cylinders, no different, swapped the HT lead too, still no difference.
The valve clearances have been checked several times, both running and static, trying to get rid of the clicking lifter.
When driving it sounds like it is has that offbeat idle of a race car, as that #8 cylinder chimes in at about 1100 rpm.
Any suggestions? It must be linked that this is the low compression cylinder.
And just to ruin my day, and add to the conundrum, I've noticed some white gooey emulsion in the breathers and under the valve covers, like you get in England in winter, except the temp here in Philippines never drops below T shirt weather.
