Got the motor pulled today. All in all not too bad. One of the exhaust manifolds had a stripped nut at the collector so I couldn't drop the Y-pipe out of the way. That and some of the electrical connectors were tough to get at but once we knew it was free, it slid right out like nothing.
A buddy is loaning me his engine stand so I will split the motor and trans and get the engine on the stand. Pull the heads as I had 3 header bolts break off in the heads : (
I will run them up to the shop up the street from me and have them fix em. Maybe see what they will charge to have the bigger valve upgrade done to them.
What should I look for on the botom end when I pull the heads? I will pull the pan as well for inspection and to do some upgrades.
And curious. The 4L60E. When I pulled the driveline out of the back of the trans, all the fluid dumped. Is that normal? Blown seal/bearing? Or is that a normal thing? My brother was here and said it is, I was saying no. Who is right?
No clue how to do a leak down test. I have no test equipment to even do compression testing.
