I couldn't find any alternator mounting brackets/kits for an early Nailhead so here's what I did...
Removed and ground smooth the front tab from the stock generator bracket. Cut a 4" long piece of 1" wide 1/4" thick steel and drilled two holes that lined up with the pre-existing holes.
Next up was a couple of mounting tabs. I used the same 1" wide 1/4" thick material.
Tacked together...
The corners of the tabs hit the alt. body so I rounded them off and welded it up.
Tacked together...
