Willowbilly3
A *real* tin magnet
Progress update. I rebuilt the carb, new points, cap, rotor and wires and a new ignition switch. I still need to run the valves but it pops right off, idles smooth, no smoke. Not bad for a 30 year slumber, engine sounds strong. Also started checking the electrical and almost everything works except one rear turn signal, and it needs a dimmer switch, lights go out when you hit the brights. I removed the seat and old mats, scrubbed the whole inside out with some good degreaser and steel wool. Now I need to dump that 5 gallons of rotten gas and get the tank cleaned and re-installed. New hose, grommet, float and gasket on the way from LMC.
I'm out to install the clutch master and slave now.
