DozerII
Got some strength back in it now. [P[P
Coming along nicely
Sometimes ya just have to move yourself to get back on the horse.
Looks great.
Sorry you didn't get any help here. Sometimes these posts go by so fast people forget. I'd suggest you look at several of the build threads here. Also look at Rat Rod Bob's most recent build on You Tube.
In my opinion 2" by 4" by .120 wall is enough but heavier is never a problem. I've never done air suspension but thousands have.
Just keep searching You Tube builds and build threads here on UDS.
I personally think the wood 2x4 mock up is a waste of time, but that's just me...
My fav method for frame layout is to do a full scale side view chalk drawing on the floor. First draw the profile of the cab then a line representing the ground level where you want it all full suspension drop if you are bagging it. Next draw a line representing the bottom edge of the frame rail. I usually put it a couple inches above the floor if you want to lay frame, this allows for tire squish. Now draw the engine/trans in profile, keep the oil pan at or above the bottom of the frame rail for safety. This all allows you to see where the engine sits in relation to the firewall, farther forward makes the trans tunnel smaller, something to consider in a small pickup cab. Now draw the wheels/tires where you want them, think about the front axle position in relation to the engine, you need room to fit the rad, lower and behind the axle looks better, but you also have to think about where the steering will be, tie rod, etc. and if you are using side steering or cross steering. Now you can draw the frame rails, leave some room between the rear kickup and the axle for snubbers. You can now figure out the suspension design, 4 link or ladder bar with Panhard rod, truck arm style, whatever - and where to put the bags and shocks, gas tank, battery, air tank, pump, so on. Easy to just rub it out and make changes 'till it looks right. I actually use the frame drawing as a template to lay the frame pieces on and tack them together, stack both rails together and clamp them so you can get them identically shaped.
This is what works for me, hope it helps..![]()
