Neverdone
Stopped by and checked on her yesterday.
Cheap solar charger is still doing its job. Flashing blue light and voltage output alive. So despite the reviews on the HF website, so far it has my vote as a good investment! Dropped off a couple things to be installed on my next trip. First is my new to me 47 MI license plate.
Next is my emergency get home idea/ convenience lift option. Since the then sits on the ground and is such a bear to lift unless you can pump up the bags, I decided some sort of specific jack for the front was in order. The other day when I was at the local pick and pull I picked up a $2 space saver jack. I trimmed up the lift plate and welded on a piece of 1/8" plate with a couple holes in it. Under the grill there is a tube that I typically jack the car from. The idea is that I am going to bolt the jack to the tube using some aircraft nuts so it never falls off and it will never be seen there either. Next I am going to build a special linkage so that I can get to it and crank it up. [
Still waiting on my flanges....
