LUCKY DEVIL 13
Greasy Gearhead
If you have a Hobby Lobby store near you, Over in the model section they have a lens making kit. It is simple to do.
Cool I will check that out thanx!!!!
Anyone ever use one of these turn signal switches?
I've ran those before. I like the heavy duty one the best. It also has hazards i believe.
Do you have a 2 prong flasher or 3 like shown and does the cap on the arm have a bulb in the end of it, IT looks like it should. If it is not lighting up with the flashers on, The yellow wire more then likly is going to that. You migth have to wire the red and yellow together if you have a 2 prong flasher. I had to do that before.
Is that the speedway one? If so I have the same one. There was two sets of directions that came with mine. I didn't use the directions posted. I used the ones that looked like they were hand written and photocopied.
If that helps any
Shouldn't matter what side of a 2 prong flasher it goes to, the other side of the flasher should go to acc. power.
Bypass the flasher with a jumper wire and go from there.
What do you mean? I am very new to wiring I'm sorry I feel so damn stupid
Take a wire and connect it to + side of battery and the other end to the red wire (disconect from flash relay first) flip the switch to one side or the other lights will come on and stay on. them touch the yellow to the jumper to see if the bulb on the switch arm comes on. if all light lite up doing this the flasher relay may be bad.
After thought, the switch housing may not be gounding out if your colunm is painted or you have rubber mounts. but if you are not worried about the switch light then problem solved [cl
try wiring it to a 3 prong flasher like the instruction show.
