SugarRay8
From the score you got from your uncle, you could build 2 more Rats. Sell 1 to pay for your other 2.....
I was pretty much thinking the same thing.
I like it as a one peice. I worry about the plywood rotting out on you eventually though.
Spray the bottom with rubberized undercoating, makr sure you get the edges.
you can get stuff that is polyurethane that also has stain in it("Polyshades"). Paint on a coat, let it dry. Paint another coat, it gets a little darker, and seals it better. Etc, etc. If the plywood is exterior grade, it will be fine. And even if it's not, with several coats of poly, it will last at least 3 years, probably more. Oh, and get the water-based poly because it is so easy to work with. Just dont ever shake the can, always stir so no bubbles get into the mix.I would eurethane the heck out of the wood floor top and bottom. They make a satin eurethane so it wouldn't be shiney. Do all the edges as well and it will seal it up pretty well
Any updates? [P![]()
there is a nice 42 dodge 1 ton that my neighbor brought home that he wont let me have.[S not like I need it any ways. I got to many projects to list on one piece of paper anyway. nice rig.
