smallfoot
Is that hinge your fab work or did you buy it? Can you review how it went? They look slick.
Is that hinge your fab work or did you buy it? Can you review how it went? They look slick.[/QUOTE
Are we talking about the suicide hinges?Yes I made them, using smaller square tubing so it would fit my door jamb.
Not all front ends are created equal.You'll have a hard time getting the look you want with the nova sus,like the S10 they dont look as well going fenderless.You can move the cab back but the frame gets wider as you go back causing some mounting problems.Some guys have used extended cab
S10 frames and slide the cab back but you still have the front suspension that is not very appealing.My 53 build is on a s10 frame but im not going fenderless.You might google rods on s10 frame to get ideas how your will look.
Sweet build! Did you use plastic air lines? What type of connectors did you use, I have some tees that keep popping apart...
