I am putting in an electric fan and wondered about a relay. I was just going to wire it to run with a toggle switch that was keyed power. wondering about a relay and did I need one? have to have one, what the heck is it for ? I know nuthin'
A relay is basically a heavy switch designed to carry big loads/amps. You can still use a toggle switch, but it will only signal the relay to open or close.
This way, your switch doesn't have to be wired with fat gauge "hot" leads, and it won't melt down from the heavy load. You can wire the switch to provide the relay with ground as its signal if you want. Then, you have NO hot wires at the switch.
Like RPM says, pick one up and read the instructions/diagram. It's easy.
Has anyone here run an electric water pump on the street.They work great on my drag car with an electric fan. I would like to have a dash mounted switchable unit that powers a relay turning on the water pump and powering the thermal switch to turn on the fan as needed. Also couldn't you use a rheostat to control the speed of the fan since it is a DC motor.
