Skip
Wow. The 39 is getting closer every day. Installed a new Speedway 20-circuit wiring kit. Loving it. Finally figured out that I don't have a neutral safety switch. Here's why.
89 S10 Chassis Donor was 5-speed.
305/th200 from an 85 Monte Carlo
Replaced the 5-speed steering column from the s10 with a later model automatic column. Early 90s, the guy said.
Sooooo, now I have a column that never had a NSS and a transmission that never had a NSS.
Has anyone come up with a simple cheap way to get a NSS back in the mix in a situation like this.
I have seen the after-marked add on switches, andI suspect that is the way I will have to go, but I like making things work if I can. Its more fun that way.
I don't mine spending money on safety stuff, but why, assuming I can make it safe without spending a bunch of money.
