wrecker55
started my work truck this morn, 30* out, oil pressure didnt come up, usually 60lbs when its cold. I have a lt1 383 1 pc rear main seal, I pulled the pump, was filled with silicone from the pan gasket seal, disassambled the pump and thourly cleaned it out, checked the spring and piston 4 free movement. pump works good on the bench. I nstalled it and fired up the motor, no pressure yet, think I may have pushed a plug outta front in the cold weather?
