Thanks Preacher. There hasn't been anything update worthy lately, but a lot of boxes have been showing up from Summit. Everyday the UPS guy glares at me more and more as he carries in another couple of heavy boxes.
I expect our Auditors at work to come in any day and check the books to make sure I'm not paying for this stuff with company funds.
The first thing to come was the stroker kit. It is a Scat setup with forged rods and Keith Black forged pistons. What a nice piece. It went together and in with so little effort. There is almost no drag when you spin the rotating assembly over and the pistons are the shortest I have ever seen........guess they do that to clear the crank.
I then installed the Ford Racing X303 cam and roller lifters. This is the same cam my Son Don is running in the 306 Ford in his T and I love the idle and the way it pulls. Next was a Comp Cam double roller timing set and also one of their lifter retainer setups. I decided to go with a regular Melling oil pump as a high volume one might suck the pan dry on hard runs. I am using a Bronco rear sump pan with only 5 qt capacity because that is what I originally built the car around and their isn't room for a larger capacity pan.
Then came the cylinder heads. I wrestled with the decision of what ones to order for a month, and finally settled on a set of E Street heads from Edelbrock. They fit my budget of around a $1000 for the pair, and seemed to be big enough to let the engine breathe well. A day after I ordered them I had a scary thought that their ad didn't say anything about working with roller cams, so I called Summit's tech line. They weren't sure either so the next morning I called Edelbrock and they informed me these heads were designed for flat tappet cams, not rollers! They said they would work, but would limit my rpms to 5500.
I had no choice but to send the unopened boxes back to Summit and reorder a set of Edelbrock Performer RPM heads. They were a couple of hundred more, but they are designed for roller cams and breathe right up to 6500. Summit was super and shipped me the new heads without even getting the old ones back yet. All I had to do was fax them a copy of the proof that the old ones were on their way back via UPS and they shipped the new ones, only billing me for the difference in cost. I LOVE SUMMIT. They always try to do the right thing and make it easy.
So, the new heads showed up Friday and I of course had to put one on to see how it looks. Plan is that today I am going to paint the block black and then I can put the heads on for real sometime this week. I'm really excited to get this engine fired up. A member on another forum has some desktop dyno program and he worked up some HP numbers for me. It peaked out at about 424 HP and that was with the other heads. So it should pull my little 2000 lb T around pretty well.
Here is the Scat crank in place......
Pistons and rods installed........
And the one head laid in place.......
