Neverdone
Things just aren't going my way.
I have three daily driver vehicles. All of them now have some sort of an issue.
My poor old beloved truck, I pulled up to the gas station friday, shut it off pumped some gas into it, went to start it back up and nothing. Fuel pump not running, think its the sending unit. Made a quick call and had a buddy come show up with his truck and we tow strapped it home. Had this same issue about a year ago, dropped the tank 3 or 4 times, never found any issues, just one day it started working again. I pretty well had it narrowed down to the connector on the sending unit then, but I have no idea. Put in a new fuel pump, pump relay, cleaned up and tightened up the plug outside the tank, same for inside the tank, the only thing that seemed to make a difference was the plug outside the tank. Ran a wire direct from the battery to the sending unit and nothing. Actually it didn't even spark, like it was not making connection at all.
My Monte Carlo, she was driving it earlier in the week (tuesday I think) and the dash lit up like a Christmas tree (Trac off, ABS, Service Traction System). Plugged it into my buddies scanner and there is something screwed up with the right side of the car as far as sensors go.
My Jetta TDI has some sort of idling issue. Feels like it might be beating on 3 out of 4 cylinders or something, possible balancing issue, fuel delivery, I have no idea. It doesn't throw any fault codes and it only does it when it is idling, and not even all the time. Not sure what is going on there but since it is a VW I am sure it will be expensive.
Three vehicles, never thought I would need to bum a ride to work, but if something gets worse on the Jetta (what I am driving now) I am in big trouble.
