icebox
I was going to Z my frame . But that idea would not work . So I am going to channel my cab 6 inches. I welded in some temporary 1 by to see if I would have enough room . It looks good I even put the seat in . I want to get it even lower so I was thinking about notching 2 inches off of the top of the frame. My idea is to take some 3/8 inch thick 2x4 tubing and weld it to the inside of the original frame . I plan on hole sawing some 1 inch holes threw tho original frame to get some more weld on it. Then cut the top 2 inches of original frame off of the top. Do you guys thing that it would be ok.
icebox
icebox
