The steering linkage looks pretty close to the radius arm but I could be wrong?
Why does it have both and electric fan and a mechanical flex fan? And what on earth could the mechanical fan be doing anyway?
35K and the the best they can do is cheapo flex rad hoses?
Maybe they could eliminate the arm chopper mechanical fan with some smooth wall rad hose?
The carb looks pretty big for a SBC? Especially since it'll be running on 5 cylinders after it smokes the plug wires that are laying on the headers.
There's something fishy with the belts and the alternator looks to be running kind if close to the frame?
Is it just me or is the throttle cable not attached to the back of the carburetor at all? Looks to me like it's just attached to the firewall and the pivot ball on the carburetor maybe it is I just can't see it
^^x2^^
I see the mechanical fan spinning around unshrouded, doing nothing, except waiting for an accident to happen. The gas pedal linkage kinda will work but is not very secure. I'm a fan of tucking the spark plug wires away out of sight, but this arrangement doesn't look that good.
If you add all of these things together to get a theme, you realize that the builder was not a very good engineer, so you have to wonder about all of the other things he cobbled up, like brake linkage, suspension an the rear, driveline angles, and dash wiring.
The fan distance was the first thing I noticed too, there is plenty metal to remount for that rad to get closer and it might look better behind the plane of the headlights imho.
From what I can see in the picture, it looks like a pretty fine hot rod with a few minor details to be straightened out. Nothing to be gained by speculating what else might be wrong with it when you can't see anything.
I still can't imagine what that inner belt is running on the passenger side? Surely it doesn't have a smog pump.
It does look pretty solid built from those pics, but a closer look would be wise if thinking of buying it. I agree, mostly minor stuff you could work out pretty quick. Sometimes an extra set of eyes is helpful to see things I've missed.
Looks like a typical shiny but poorly engineered, fishing for money kinda car.
Usually assembled by people with limited hot rod knowledge.
If he's listing it as a "Model A 5W" then he doesn't know much about early Ford models either. There was no "5W" Model A. It was just a Coupe - Window designations did not come into play until the Model B.
