One Ton Dually Front End
Gofstt69
New member
Jun 1, 2015
2
North Kansas City, MO
I'm trying to put together a plan for my "46" International. I'm considering using a 1 ton dually rear and need some help on the front. I would like to use the 8 lug front wheels and brakes with a dropped I beam front axle but not sure how to make it work and what parts I need. Does anyone make a spindle that will work with this combo or any other ideas. Still in the design stage and searching for parts.
somebody will correct me if I'm wrong, I think 8literbeater used a Ford super duty. They are an I-beam already much like the old ones. The parts for the front would be readily available and I think the bolt pattern would work for the big wheels.
ok so I got a dually rear and front end out of a 1972 Winnebago and it is a solid drop I beam with the 8 lug wheels but it has drum brakes now if I can find a Disk brake setup for it it will be what I want
