Cruise Moab
So, we're 30 days out from a big Toyota 4 wheel Drive event over in Moab Utah called Cruise Moab. I go about every other year. I decide this year to take the Patina Cruiser back for a second trip. Last time was blast and many people really got a kick out of seeing a bone stock 50 plus year old rig do as well as it did. However, as this is a rig I built to ultimately sell, I wanted to go through the engine because it has very low oil pressure, it leaks pretty bad and puffs oil through the valve guides. (Although it runs like a Swiss watch)
Then, while we're at it, the 3 speed trans leaks pretty bad too and it needs an input bearing and a set of synchros. Next, since I had to separate the tranny from the transfer case I might as well go back together with an Orion 4:1 case and gear set. Then I got to thinking, now that I'll be geared low enough to climb nearly anything, I'd better throw a lunch box locker in the rear end. Last, with all this, it'd be a shame not to replace the clapped out stock suspension so, I ordered a complete suspension kit from Old Man Emu.
This past week after work and this weekend I pulled the Engine out and apart for inspection. I'll post what I found / find this coming week.
